Micrologix 1500 & Microscan MS-820 Communication Problems
ELake20
Aug 2003
N. Michigan
271
I'm using a Microscan MS-820 bar code scanner to scan bar codes on plastic parts. I have everything setup, but cannot get the scanner to communicate with the 1500. I'm using Chan0 for the HMI, and Chan1 will be used for the scanners. The orange LED will not light up on Comm1, and when going into the channel configuration menu in RSLogix, Chan1 is filled with zeros which is telling me that it is either disabled, or not working at all. The Baud rates and everything match....
Thanks in advance.
You need both the channel configuration and some ladder logic to bring in the buffer data from Channel 1 into memory.
Post your program file or excerpts from it and folks may be able to help.
This might be a good opportunity for users to share some "best practices" ladder code for managing Channel 1 of the MicroLogix 1500 in an ASCII input application.
130
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
947
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,226
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,444
