JohnRatHolten
Hey All,
A question about replacing the Procesor module on a MicroLogix 1500.........
We have a machine that we bought last year, there is an inherent problem of the PLC (or the program) causing our system to occasionally fault,
and we have to switch the PLC from REM to PROG, PROG to RUN, and back to REM.
The OEM acknowledged the inherent problem when they commisioned the machine and the Tech/Eng made sure he
told everyone what to do about it.....
Apparently, someone tried to do that and managed to break the switch (and of course no one will admit to it)……
Luckily, it is stuck in the REM position, and I was able to plug in my laptop and go online to clear the fault.
The OEM did give me a copy of the program, but has since been unresponsive to my requests for information.
I bought a replacement processor just in case the switch fails completely..... This is a 1764-LRP
Now, I’ve not had any real experience with setting up a ML1500, so I figured I ask a few things before I attempt anything.
I see that the processor module snaps into the base unit and the programming port (channel 0) is on the base unit
connected to an Ethernet Interface, which is how I go online.
Are the communication protocols between the Ethernet interface and the base unit predefined?
Can this be as easy as snapping in the new processor, and downloading the program through the Ethernet interface?
Or, is it more involved than that (I read something about a comms toggle push button on the processor)??
Any input would be appreciated.....
Regards,
JohnR
Regards,
JohnR
