Micrologix and Sick Inspector?
asteroide
Jul 2010
der
158
Hello Friends
I need to control a sick inspector I40 (VSPI) over Ethernet.
I have seen that it is posible with a CompactLogix, but I have a Micrologix 1100 and 1400.
Do you know if is it posible to control with a Micrologix?
Do you have a sample program o documentation about how to do that?
Thanks in advance.
I have a sick scanner clv630 with CDM420(for ethernet interface) and would like to simply stop the machine if it reads a wrong barcode. in Clx...
3,481
I have an application where I need to put a Sick CLX490 in "Sleep Mode" and put it back into "Run Mode" (Laser On) utilizing the ASCII AWT...
2,280
41
91
101
