Micrologix Datalogging
junior
Jan 2006
Seattle
271
I'm wondering if the ML1400 supports datalogging float numbers or is the datalogging capacity the same as the ML1100?
Also, since the ML1100 doesn't datalog floating numbers, what would be the best workaround? Would it be converting the float to a string and then datalogging?
Jr.
I don't have a ML1100 or a ML1400 to play with. But When I try to program
a floating point number (offline )with a ML1100 it gives me a invalid number error.
It ask for a 16 bit word or 32 bit word. The work around might be using a
"Long" data type and have an implied decimal point.
When trying to program a ML1400 (offline) it took the floating point number without an error flag. Try it if you have a ML1400.
Jr.
You say the ML1100 does not do float so almost certainly it won't do string
the option that will work is integer.
Convert your float into an integer and if need be because its a small number do it with a multiply by 10 or 100 using an integer as the destination as long as the result wont exceed 32767.
The ML1100 does do floats (or they're called longs), it just won't log them using the datalogger function. I'm trying to figure out what would be the best way to be able to datalog the floating numbers. Not sure why they wouldn't incorporate this as I would think that you'd be logging a float more often then an integer.
Hi Guys, New to this forum. I am in selection phase for a Data-logging project. Requirement is given below. Data should be stored in battery...
3,958
Hi, I need to do some simple datalogging with a Micrologix 1400. When someone logs in thru the HMI and starts a system I need to log the...
3,515
I have set up datalogging in a micrologix 1100 and can then read my data with GetDataLog.exe. I read here a long time ago where someone was using...
1,758
Has anybody figured out a workaround how to datalog floating numbers in Micrologix 1100/1400? I know, you can multiply the floating number by 100...
3,561
66
