Datalogging with Micrologix 1400?
FNC
May 2010
NJ
84
I need to do some simple datalogging with a Micrologix 1400.
When someone logs in thru the HMI and starts a system I need to log the username and the system number. There would be 10 or so starts a day.
What is the best way to do this?
I have a PV 700+ touchscreen.
Are you suggesting storing all of the data on the PLC then?
Today's theme on the Forum is different ways to understand the phrase "data log".
The challenge is that you have one thing that's happening in the PV+ (the user login) and another that's really happening in the MicroLogix. My guess is that "starting a system" involves a pushbutton, but it might not.
I would take a jump to the end and ask what format you want the "data log" to take. Do you want some sort of text file ? An entry in a database ? A list on a screen ?
What you want to do with the data is going to determine how and where you store it.
Starting a system is indeed pressing a button.
I just need the customer to see the the date/time, system #, and username.
I expect this to happen 10 times a day or 3500 times a year.
Hi Guys, New to this forum. I am in selection phase for a Data-logging project. Requirement is given below. Data should be stored in battery...
3,956
I have set up datalogging in a micrologix 1100 and can then read my data with GetDataLog.exe. I read here a long time ago where someone was using...
1,756
Has anybody figured out a workaround how to datalog floating numbers in Micrologix 1100/1400? I know, you can multiply the floating number by 100...
3,560
I'm wondering if the ML1400 supports datalogging float numbers or is the datalogging capacity the same as the ML1100? Also, since the ML1100...
2,986
I have some datalogging set up on an S7-1211. Most basic controller, but 1MB of memory should be enough. A single log is 222 bytes and logs an...
422
