Micrologix embedded >9 Module
pajonec
Feb 2010
BKK
I have problem follow my picture (Micrologix1500_IO.jpg), How do additional the module more than 9 modules for Micrologix1500 and RSlogix500 configuration , My base unit is BWA.
Thanks!
Follow RSLogix500 Help : Have information like this.
Special Note when using MicroLogix 1500 controllers: When deleting power supplies and cables from an I/O configuration for MicroLogix 1500 controllers, the remaining configuration may appear to be represented incorrectly on the chassis display. This, however, is not the case.
Explanation: Power Supply and Cable items don't occupy slots. Although they may appear to do so in the configuration display, internally they are just replacing the unused slot in the diagram. Therefore, when deleting a non-I/O item, it is actually just being marked as unused. And the resultant display is correct.
Important: When configuring I/O for a MicroLogix 1500 controller, note that a 1769- HSC, and a 1769-SDN cannot be more than 4 slots from the power supply. A 1769-OB32 cannot be more than 6 slots away from the power supply. Other modules are allowed to be 8 slots away. Project verification will give an error if these modules are placed too far away from a power supply.
Hello. I am unable to find information regarding the input mapping for the embedded inputs for the Micrologix 1100. as far as I can tell, inputs...
1,614
I have a new Micrologix 1400. I have an SCP instruction that should give me a 0-4095 output on O:0.5 address. Problem is it does not ever change...
2,847
The current configuration of my micrologix 1500 embedded I/O has been configured as input I0:4 + I0:5 and I0:6 +I0:7 4ms I would like to know what...
2,284
Hello...I'm a pretty fluent SLC 500 programmer, but am now trying to develop a Micrologix 1400 program offline (1766-L32BWAA). I'm amazed that I...
13,105
Howdy all, New to the 1400. I have read the manual a few times (maybe not every word) but still can not find where the embedded discreet inputs...
13,004
