Micrologix & PanelView 300 Micro tags!
ing_barajas
Sep 2006
Hermosillo
Hi, i hope somebody can help me... i have a PanelView Micro, and need to selec "AUTO or MANUAL" to send to the PLC but i don´t knnow how do it.
if some body can tell me how link the tags in the PV300 to PLC I will be thanked it a lot...
Thanks!
RAFAEL
i just 'finished' a project using a micrologix 1500 and a pv300 (non-micro, with keypad)
you have to set a node up for the panelbuilder project that describes the micrologix.
using that node (mine is ML_1) you can access the data files in the micrologix.
the best way to do what you want is to use a auto_manual status BIT. so just have a bit that is a 1 if in auto, and 0 in manual.
For the panelview, just setup some buttons to change the value of that bit when they are pressed.
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,786
Hi everyone! I have been reading forums for some time now and they have been really helpful to me. I am a brand new member here now and have my...
4,259
Need help a source code to make timer display into hour:min descending from a time of delay 1 sec base timer. Thanks
22
5,940
Hello, Well, after fighting thru comm and cable issues from pc to panelview and pc to plc finally communicating with each separately. I have...
20
17,890
Hello! New to this group. I'm tasked with adding a Panelview 300 to a machine that currently has a Micrologix 1200 (1762-L40AWA). Which Panelview...
5,434
