Micrologix RTC
ftnguy
Jun 2013
Texas
I need to be able to write to the ML 1100 RTC from a 3rd party touch screen. I put the current time into the RTC by using the function files directly and I can display the time on my touch screen. I want to know if I can use a MOV command in the opposite direction to inter integer values into the RTC.
I'm looking to add some low Battery Status Alarms to a set of PLCs (Mostly RSLOGIX500 based). I noticed there were two possible alarms for low...
1,519
Hi, I have successfully got my system to do the following: 1. write the RTC hours, minutes and seconds to 3 integer files every 250 mS. 2...
2,114
This is a weird one. I vaguely remember reading something here about a firmware issue but I can't find the post. I'm looking at this tiny...
2,315
On the Micrologix 1100, I'm having an issue with RTC freezing. I think its only happening after a power outage. But when I go to enter values...
2,436
