micrologix with panelview plus
Narlin
Mar 2010
phoenix
320
I have been using Ethernet IP for communication between PanelView Plus 600 and ML-1100. Some of the analog OIT updates are very slow. I can see the PLC recognize changes immediately (using RSLogix 500 online) but the PanelView gets around to it at least a second or two later. Is this normal behavior for this PanelView? I have already changed the cycle time from 1 sec down to its lowest value of 0.05 seconds. That helped with screen change times, but didn't really change the analog update time.
narlin
Are you using an HMI Database Tag, or are you using a Direct Reference to the data table element ?
HMI Database Tags generally get processed at a 1 second rate, but Direct References get processed at the Display Update Rate.
Ken, i don't know that answer. I will look into it first thing in the morning. Meanwhile, can you clue me in as to how to tell the difference? I am pretty sure that i didn't even know there were 2 types.
108
Hi PLC People, I get the following error when trying to compile a Panelview Plus 7 Standard program Using View Studio V10.0 Device Shortcut is...
4,886
Hello, I am currently installing a PLC control panel and due to space constraints, we will need to install the Panelview 600 HMI separate...
3,389
Hi there, I seem to be having some issues interfacing a Mircologix 1400 and a Panelview plus 1000. All communication is done over ethernet...
2,386
HI, I would like to link (via ethernet) a PV+ to a micrologix 1100 already on an ethernet IP adresse (they are not in the same panel or location...
1,894
