Micrologix1000 loss of communications
Cal357
Nov 2013
Utah
I have a laptop running 32bit Windows 7, RSLinx version 3.60, and I'm trying to go online with a Micrologix1000 plc. (using RS-232 DF1 driver)
After performing an Auto-Configure routine, I'm able to establish comms and go online for a short while. It then seems that if i'm not actively doing something in the software, that I lose communications after only a couple minutes of idle time.
sometimes i'm able to hit 'Retry' and it connects again, other times i have to go back into RSLinx and do another Auto-Config.
Has anyone observed this issue before?
I'll bet you a donut you're using a USB/RS232 converter of some sort.
The Keyspan/Trippline USA-19HS is the Forum favorite for stability, performance, and compatibility.
I've had trouble with lots of other cheaper ones maintaining connections to various controllers over RS-232.
Grounding of the controller can also be an issue for any RS-232 connection; make sure there's a nice fat green wire from the controller's Ground terminal to a solid electrical earth strip.
Edit: Tripplite. The USA-19HS is widely available retail and online.
Working on a machine that uses an Allen Bradley micrologic’s 1000 controller. Wondering if there is away to tie in the output to an external...
2,935
Hello, i made a program in rslogix500 for my micrologix1000 plc. can i import this program into the CCW software then convert the program which...
1,493
Could someone please guide me in the right direction? I currently own a 1761-L32BWB (Micrologix1000 processor) and a 1761-CBL-PM02 (programming...
4,508
Ihave a machine with a failed Moeller PLC that I have no documented logic for, and am replacing with a micrologix 1000 1761-L20BWB-5A. Most of my...
3,393
Hi all. Ive made a small I:0/0 push button and a O:0/0 light program to test that my plc is working. I got the bush button on a 24VDC and the...
35
5,280
