MicroLogix1000 Outputs not working But has indication
So i been narrowing it down, the relays within the board still work, I put 24 V to the one pin and the relay goes click and turns on my light. BUT! something within the board must be blown to not send the signal to the relay. What sends the signal of output to energize before the relay?
Carbon Fibr said:
...What sends the signal of output to energize before the relay?
That's a secret only the AB fairies know. You need a Wizard TechConnect Contract to access that information :geek:
Carbon Fibr said:
...anyone have a link to replacing the relay outputs?
Not quite...read last sentence...
37416 - Troubleshooting an Output that is not Working
Access Level: TechConnect
You could try repair it, or get it repaired, but it's a MicroLogix 1000?
Carbon Fibr said:
...Or might just pick up a new plc
Now your talkin'!
Give it up at this stage my friend, you've bought a dud PLC, or a perfectly good door-stop.
G.
Working on a machine that uses an Allen Bradley micrologic’s 1000 controller. Wondering if there is away to tie in the output to an external...
2,911
Hello, i made a program in rslogix500 for my micrologix1000 plc. can i import this program into the CCW software then convert the program which...
1,486
Could someone please guide me in the right direction? I currently own a 1761-L32BWB (Micrologix1000 processor) and a 1761-CBL-PM02 (programming...
4,493
Ihave a machine with a failed Moeller PLC that I have no documented logic for, and am replacing with a micrologix 1000 1761-L20BWB-5A. Most of my...
3,369
Hello, Have a ML1000 communication via NET ENI module to a PanelView Plus 600 HMI running Ver3.1 firmware. In my FTView 6 I've created and on...
1,951
