Micrologix1200 Encoding
Stylingalong
Oct 2003
Kansas City
Gentlemen (includes ladies);
I am looking for some help on my latest project. I want to use an encoder to get position and then use the PLS function to make certain actions happen from that position. I am reading all the stuff that I can get. I currently use AB845H Encoders, but have access to others. O.K. Now to the real question. I am not running at high speed and only require a minimal accuracy of around 1 degree. What should I use for an encoder?
Second pleading. Does anyone have a small program that I could look at for guidance. I am vary familiar with programming on the SLC platform (no HSC or encoders).
Any help will be greatly appreciated
Connevr channel A to 0 input, channel B to 1 input, and , if used reset output to 2 of PLC.
Then go to I/O configuration and change input reaction time to 0.25 us (the minimum one) for inputs 1+2 and 2+3.
Then built your ladder with counters ....
I have a micrologix 1200 that will run one of three different timing sequence, depending on which input is triggered. I'm trying to find the best...
3,461
How to check the communication between the Micrologix1200 to Citect SCADA. I use PLX51-DF1-ENI router to communicate in scada. I tried to use...
1,350
I have a micrologix 1200 and I am trying to get a barcode scanner to talk to the COM 0 port. I know the scanner baude rate is 9600 because I...
1,780
Good day all. I have a some MAC bullet valve catrtidges (BV210A-CA1-00-BEH0-CTC). They control vacuum for suction cups that pick up various...
1,620
Can I communicate to a Micrologix 1200, going through a Panelview C600? I have this machine made by SIDEL that has a Micrologix 1200 talking to a...
1,490
