Micrologix1500 comm issue HELP!!
Jan 2014
ny
Okay so I just went into my ML1500 and mistakenly changed a comm setting for channel 0 or 1 channel config section of the programming software RSL500 and it prompted me to apply or dont apply comm setting. Now I cant get back online with it after applying. I am trying to set up a prosoft PLX51-df1-ENI converter in place of a ab ENI module that failed and have had 0 success other than successfully messing up the comms on the ML1500. Any help to get me back talking again and then getting this pro soft converter going would be appreciated. I am using the comm 0 for hmi and programming and the side port (1l to command a drive so its a little different than a normal setup. Thanks,
John
Hello everyone I have a micrologix1500 connected with RS232 to my computer, and connected to the 1761-net-dni with a series connexion from the...
2,927
Hello Everyone, Let me start out by saying I am definitely not a pro by any stretch of the imagination. What I have is a Micro850 that is on the...
2,701
Hi, I have a Micrologix PLC 1500 on which channel 0 is free. I need to take this PLC in scada via ethernet module any one can suggest a suitable...
1,516
Greetings! One of my shop's Micrologix 1500 processor's mode selector switch(soldered on the PCB) has broken off. Currently, it is stuck in RUN...
2,365
Hello everyone, Has ever happen to you this major error? https://imgur.com/YNpueNf This camed after I substitute the old Frequency...
1,817
