Micrologix1500 Mode Switch
Ryan Rose
Jul 2018
MI
Greetings! One of my shop's Micrologix 1500 processor's mode selector switch(soldered on the PCB) has broken off. Currently, it is stuck in RUN mode. We've replaced the processor since, but would like to repair the original. I can't seem to find any replacement kits that include the switch itself, or even the exact switch online. The label on the switch reads "TL39 APEM 9. K5".
I have located a potential replacement in a catalogue (attached), but am unsure of which exact configuration the switch needs. The dimensions of this model seem to be nearly identical to the one on the processor's PCB. The model is "TL..Y0". I don't know if I need single or double pole, or the switch configuration (On/Off/On, ect.). The broken switch cannot be actuated, so I cannot measure across it to find out.
Any help in selecting a working replacement is greatly appreciated.
I would say that only an ON/OFF/ON configuration can provide the information needed by the controller. All 3 positions must not be momentary.
If your broken switch has only 3 lugs soldered into the PCB, then it is a single-pole, if it has 6, then it's a double-pole.
I've gone full-circle with this, and ended up on that same page you linked to...
APEM
TL series switch
3 single pole
9 ON-OFF-ON
The rest is up to you to compare against your existing switch...
APEM
TL series switch
3 single pole
9 ON-OFF-ON
Thank you very much for your help. It does only have 3 legs soldered to the board. I can order a replacement now.
Hello everyone I have a micrologix1500 connected with RS232 to my computer, and connected to the 1761-net-dni with a series connexion from the...
2,926
Hello Everyone, Let me start out by saying I am definitely not a pro by any stretch of the imagination. What I have is a Micro850 that is on the...
2,699
Okay so I just went into my ML1500 and mistakenly changed a comm setting for channel 0 or 1 channel config section of the programming software...
1,173
Hi, I have a Micrologix PLC 1500 on which channel 0 is free. I need to take this PLC in scada via ethernet module any one can suggest a suitable...
1,513
Hello everyone, Has ever happen to you this major error? https://imgur.com/YNpueNf This camed after I substitute the old Frequency...
1,817
