Migrate from Omron CJ1 to NJ/NX
JordanCClark
Mar 2007
Michigan
610
Has anyone done a migration from CJ1 platform to an NJ/NX platform? Is there a program conversion utility for Sysmac Studio similar to Rockwell's?
While Rockwell's certainly isn't perfect, it was still a time saver.
Conversion utility is not good, even Omron says that.
Best just to rewrite the logic.
Instruction sets are different so not everything will convert.
gtsuport
Hi.In the S7-300 plc, DB100.DBB10, whose data type is byte, is transferred to db23.dbb10, whose data type is bool, with the move command. This...
809
We migrated a project from WinCC V 7.0 ( Windows XP) to WinCC V 7.5 (Windows 10).Every things okey .When the language translation button is...
420
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,259
Inexperienced user here. We are upgrading servers and currently have RSLinx Classic Lite with a dozen SLC505s on it. The new server will run FT...
814
Hi Group Hope everyone is ...not too shabby. I developed a program using RSLogix 500 for use on a MicroLogix 1400. I need to update to a newer...
4,459
