Migrating program from ED1000
volzon
Feb 2012
Norway
Hi.
We have a BBC ED1000 PLC from 1987. We are now planning to replace it, but having some problems rewriting the program into a new PLC. We have a print from the program, but no documentation om the function blocks.
I have attached one page from the program.
Is there someone that is familiar with ED1000 programming?
What I've found out so far:
X0,5 = Digital input
Y0,1 = Digital output
F0,2 = Global variable
f30,0 = Local variable
& = AND
>=1 = OR
My questions:
1. The "1" inside a square = ????
2. S R = SR flip flop ???
3. The "T" inside a square = Timer? How does it work?
4. The outputs, for example Y0,1 is only controlled on this page in the program. Y0,1 goes high when F0,2 and F0,3 is high. But when does it go low again? First cycle with sum of F0,2 and F0,3 = 0?
252
Im trying to migrate a program from Mitsubishi to Siemens PLC using TIA PORTAL. Can anyone help me to understand and translate the logic in the...
2,911
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
70
We are upgrading our FTV ME v8.1 program to SE v12. Is there any way to migrate the alarm tags (about 600ish) from ME to SE. The import / export...
853
Can it easily be done ? We have a legacy project written on Allen Bradly 1746-l542 with Several racks of some on an extension rack and some on A...
1,760
