Migration Panel View
Kristian
Jul 2008
Guatemala
20
Hello, I'm triying to migrate to panel view 300 micro to panel view plus 400
To convert I'm using a FactoryTalk Machine Edition, but when it's done showme this
Tag TEST3: Bit Array tags are not supported. Tag will be converted as a memory tag.
Bit and LSBit triggered alarms that used a Trigger Tag with a Bit data type will only be able to trigger a single alarm after import.
Alarm message Ack option not supported.
Screen 1 - Main: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (0,32)."
Screen 1 - Main: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (0,40)."
Screen 3 - SS_Status: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (24,0)."
Screen 3 - SS_Status: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (0,0)."
Screen 3 - SS_Status: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (24,16)."
Screen 3 - SS_Status: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (24,32)."
Screen 3 - SS_Status: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (0,8)."
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (0, 8).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (0, 16).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (0, 24).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (0, 32).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (0, 40).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (0, 48).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (64, 48).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (64, 56).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (0, 56).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (64, 8).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (64, 16).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (64, 24).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (64, 32).
Screen 4 - SS_Faults: Message display object will be converted to Multistate Indicator object at (64, 40).
Screen 6 - Sync: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (24,16)."
Screen 6 - Sync: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (24,32)."
Screen 6 - Sync: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (0,16)."
Screen 6 - Sync: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (0,24)."
Screen 8 - Turntable_motor: Wrapping a value from its maximum to its minimum and vice versa when ramping at (104, 32) not supported.
Any advice will be appreciate to much! thanks in advance.
Well, all your LSB messages refer to the original using Least Significant Bit to trigger something. Likely, the original programmer used an integer tag and examined bit 0. You may need to rework how that's being done from the PLC side... use a bit tag instead.
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,705
Hello to all. I have some doubt on Quickpanel control part no.IC745CGL06MTD-EF which is client request me to upgrade. From the GE catalog i just...
2,671
I have a panelview 1000 model number 2711-t10c8 touch/color and i need to migrate it to a panel view plus 1250. I have the migrations...
1,753
I am in the process of migrating a Quickpanel Jr screen that has a few dead pixels resulting in hard to read numbers. The current PLC is a old GE...
2,274
50
