minature ac 3 phase motor
jimcav
Dec 2004
new jersey
229
Hi guys,
I am looking for a very small three phase motor about 1/15 to 1/8 hp.
needs to be about the same size as a nema 23 frame stepper motor.
Jim Cav
IS there a reason it has to be 3 phase? At 1/8 to 1/15 HP you can find single phase and 90vdc motors off the shelf at http://www.grainger.com
I did find a metric 3PH 1/6 HP:
http://www.grainger.com/Grainger/productdetail.jsp?xi=xi&ItemId=1611789213&ccitem=
The 90vdc models its easy to find a 1/8HP model:
http://www.grainger.com/Grainger/productdetail.jsp?xi=xi&ItemId=1611576698&ccitem=
The DC models may fit the nema size aspect better than any AC model if you want off the shelf.
If you use a 90vdc model at full rpm then you dont necessarily have to buy a controller, just use a bridge rectifier. If you need less than 1800 rpm look at a speed controller or the gearmotor models.
I went on a PLC course a little while back and they had a production line mock-up with a mini conveyor belt and a few motors and sensors. Does...
2,566
234
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
555
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,392
We have an existing VSD where a three phase circuit breaker feeds the drive, and two phases also tee off to a contactor, which is energised to...
1,509
