dash
Version 16 Comment/Question:
OK, the first item is the new Unicast connection that is available for EtherNET/IP connections. I really thought that this was also going to be available for I/O connections in addition to producer/consumer connections. From playing with it this morning it appears this is only available for producer/consumer connections for V16 processors and up. Does anyone know if this will be supported for IO connections in the future?
The last item is a request for clarification:
[The question below came up due to a statement in the tech support document 30621 DH+/RIO Message Management in ControlLogix - Tips to optimize the 1756-DHRIO. When to use the 1757-ABRIO module]
On a 1771-ASB module is it true that it can only support ONE BTR/BTW at a time for the whole rack? In the PLC-5 projects I have done in the past I do not remember this being explicitly pointed out. The only item I remember doing is interlocking multiple BTR/BTW to a single module in a local or remote chassis since it could only handle one at a time. I do not remember this being an issue for the WHOLE remote chassis.
In the document listed above the question comes up on page 4, item one on the list. "A Remote I/O adapter module (1771-ASB) can service only 1 Block Transfer at a time. So, when working with a rack with multiple analog modules when possible try to set up the message manager to enable 1 BTX per rack or spread them over multiple racks per group. "
Thanks for any insight,
Darren
Darren
