Mistubishi E200 HMI Cable
onkalolo
Jun 2015
UK
Can I use a CAB30 cable for an older E200 series HMI? As well as an E1000 series?
(I expect I'd need a CAB5)
Thanks in advance!
edit: I think I've just discovered my initial thought was correct and I will need a CAB5, the pins are apparently slightly different! Would be helpful if someone could confirm this, though. Cheers
I have to do some scripting in a Mitsubishi GT27 to read a CSV file off a USB stick and populate a series of registers in the PLC (FX5U). There...
2,542
Hello, Have a question that can hopefully have a simple answer. I want to track machine cycle counts to an HMI. Mitsubishi A series PLC and a...
3,616
Hi, Does anyone know an easy way to show and hide buttons. I know on the GT11+ series you can script or use the trigger, but on these there is...
1,680
Hi, Unit shows an E9 error (Supply Off) even though the supply is on. Has anyone else experienced this problem before? Should I be ordering a...
3,582
Does anyone know where I can locate software and a manual for an older Mitsubishi FX2-32MT plc? I am new in the PLC world and am currently...
1,855
