Mistubishi GT27 Scripting
JRoss
Sep 2006
Dillsburg, PA
184
I have to do some scripting in a Mitsubishi GT27 to read a CSV file off a USB stick and populate a series of registers in the PLC (FX5U). There can be anywhere from 1-30 lines, each line would have two values.
I have done a little scripting on the GT2000 series, so I can get this done eventually. I'm just wondering if anyone out there has some ideas for doing it efficiently. Actual code samples would be fantastic!
Thanks!
Not really, but thanks anyway.
I wrote a script for another customer that read a file off of a USB stick and populated some PLC registers with the result, but that was just a single string, not an entire list of values. I can brute force it, I just was hoping for something more elegant!
I've scripted many times to log historical trending etc but not to read in values, however could you investigate the recipe function on the GOT, there is some explanation of this in the GOT2000 series manuals?
Steve
Hi, Can I use a CAB30 cable for an older E200 series HMI? As well as an E1000 series? (I expect I'd need a CAB5) Thanks in advance! edit: I...
1,446
Hello, Have a question that can hopefully have a simple answer. I want to track machine cycle counts to an HMI. Mitsubishi A series PLC and a...
3,616
Hi, Does anyone know an easy way to show and hide buttons. I know on the GT11+ series you can script or use the trigger, but on these there is...
1,680
Hi, Unit shows an E9 error (Supply Off) even though the supply is on. Has anyone else experienced this problem before? Should I be ordering a...
3,579
Does anyone know where I can locate software and a manual for an older Mitsubishi FX2-32MT plc? I am new in the PLC world and am currently...
1,855
