Mitsi Q Ethernet
myfriendstan
Aug 2007
Coventry
Mitsi Q - Ethernet - anyone know how to read bits using 'readup' instruction? (GX IEC DEveloper) Tried using k4M100 format in place of D register - crashes PLC!
Unfortunately I don't have permission to modify code in source PLC - data in register format can be read ok, however I need to read status of a couple of bits in remote PLC - but I think I may have to get the other engineer to meet me on site to modify his code in the way you mentioned.
hi all regarding : mitsi q series ethernet qj71e71-100. there's an old coax network at a client's chicken factory that's fallen over. it...
1,929
Hi, I have two systems each consisting of a Q03UDE connected to a Beijer E1070 all over Ethernet... I would like to share some REAL's over the...
3,833
Hi Scenario is a Mitsi PLC which is connected to an E- Terminal using a CPU direct serial cable. I have been told that i can use transparent...
2,511
Hello again.:D I am attempting to set up ethernet coms to an A series Mitsi processor. Processor is A1SJH/ Ethernet card is A1SJ71E71N3-T...
4,213
Hi, I have been asked to add a module to an existing PLC, which has a processor Q2AS(H). I have looked online and found A1SJ71QE71N-B2 and...
1,795
