Mitsu Q02H --> GOT1000 communication problem
Nov 2007
Burlington
Greetings fellow Mitsubishi fans,
I have a quick query for those of you who have more experience than me with the wonderful world of Mitsubishi products.
Currently I have a Mitsu Q02H connected on a network with a laptop and GOT1000.
While I can communicate individually through the laptop to both the PLC and the GOT through the network, I am unable to have them communicate with eachother.
I was just wondering if anyone could give me a quick walkthrough on the settings required for the communication and if it requires any actual code to work properly.
Best Regards,
-YearofMitsubishi
I would assume since you mentioned your laptop can communicate with either over the network, you probably are using Ethernet. Laptops don't have the means to connect to MELSECNET or CC-Link.
Check the Connection manual, as there are example settings for the communications using the QJ71E71-100 and GT15-J71E71-100.
Make sure the driver gets downloaded, make sure you set it up for Channel 1 on the GOT, and you set the IP information correctly.
Connection manual comes with the software if you choose to install the manuals, and then will be available in the help menu.
But the number is SH(NA)080532.
Hi, I have a Siemens TP170B which I need to connect to a Mitsubishi Q02H. The only port available on the Q02H is the RS232 6 pin mini DIN...
3,675
Hello everybody. I encountered a problem - I don’t know how to update the firmware on the Mitsu MR-J5-40G-N1 (ethercat) servo amplifier. My...
403
Hello to Mitsubishi Electric experts. I have been tasked with developing an application that gets data from a MELSEC application, using MX Sheet...
1,253
This is my first on the job exposure to messing about in a PLC with a PC. So far it hasn't gone too bad but I'm having a problem and it all...
2,630
Hi all... help on Ethernet comm, between builtin EthernetQ03UDE to Laser Marker I'm using sp.socopen i cant open the port... is there any command...
2,309
