Mitsu Q03UDE <> MD-X1000 Keyence Laser Marker
REZAR
Aug 2003
Jakarta
95
Hi all... help on Ethernet comm,
between builtin EthernetQ03UDE to Laser Marker I'm using sp.socopen i cant open the port... is there any command to send string data "WX,DistancePointer=1" ?
any comments would be great,
thanks all đź‘Ľ
thanks all đź‘Ľ
Maybe you should check SP.SOCSND instructions to send dat from PLC. I have attached built-in ethernet manual as link below at page 62 to 110.
http://www.atronika.com/Mitsubishi/PLC/MITSUBISHI_QnUCPU-User%E2%80%99s-Manual-Communication-via-Built-in-Ethernet-Port.pdf
Hi Wasan, thank you, i'm also use same manual, PLC will stop due to error if im using SP.SOCSND without open its port.
If i'm not get it wrong, it should be open port first, then send the data, and go read reply, then close its port.
Hello everybody. I encountered a problem - I don’t know how to update the firmware on the Mitsu MR-J5-40G-N1 (ethercat) servo amplifier. My...
403
Hello to Mitsubishi Electric experts. I have been tasked with developing an application that gets data from a MELSEC application, using MX Sheet...
1,249
This is my first on the job exposure to messing about in a PLC with a PC. So far it hasn't gone too bad but I'm having a problem and it all...
2,628
Hello all, this time is my question somehow theoretical, but with high practical impact. Let asume we have simple program and we have to...
2,285
All, I have a machine just in from China that I need to upload back-ups for. It came in with very little documentation, and what I do have has...
1,527
