Mitsubishi A-series Index Registers
Killercal
Aug 2006
Ontario
150
Hello, I was wondering if there is a way to increas the index registers? Right now there is Z0 to Z6 and I need [2] more. Is this possible to do? If not, what would my next option be?:confused:
The number of index registers as far as I know is dependant upon the CPU you are using. An A1SJ CPU has one Z index register and an A4U CPU has 6.
You may want to consider the V index register.
Hope this helps.
I'm using an A2USHCPU-S1. There is only 6 Z index registers and 6 V index registers. I've looked at the manual and actully found where it explains this. I will use the V registers!
Thanks for your response thomas.
I am sure you can use the V registers to do what you want but I would question the need to use all of those index registers. Medoc only used to support the first Z and the first V register but I never found a case where this was not enough. Are you sure that you cannot reinitialise and re-use the available Z registers to get what you want. Keeping track of all of those index registers might be confusing.
Andybr
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
90
101
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
319
Hi, I have a project with a R04CPU, RD77GF16 and a RJ71PN92 modules. The cell is given to me to change the program since the previous integrator...
342
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,236
