Mitsubishi Alpha 2 USB Communications
Zimcocomp
Jan 2011
MA
Has anyone had success communicating to a Alpha AL2-24MR-D, PLC using a USB to RS232 adapter? I have tried two different adapter models without success. I don't want to keep wasting money trying different brands. I am changing program control over to a newer notebook (no serial ports) from an older PC which works fine. I have a 9 pin interface connector on the PLC.
Thanks in advance.
Lynn
bump
I managed this with cable my boss gave me, but now I'm trying another cable and I can't make it run.
Anyone has any idea what might be causing this?
Yes, it works fine with one (brand unknown) but with a Brainbox adaptor it does not. I have four different USB to serial adaptors, pending on what equipment I use I have to swop them around. As above mentioned in the previous reply, this depends on the chip set being used.
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
41
I am trying to connect USB to RS232 cable to the RS232CAB that is used with the Alpha series PLC. I am getting a failed to open com port error...
1,349
I have downloaded a project from a Mitsubishi Alpha PLC that we are having issues with and the representation is Boolean. Is it possible to...
1,669
Simple question, is there any way of saving Function Block Output values on power down in Alpha2? Or more general question, is there any way of...
1,571
Hello ALL, Have some experience with PLC programming, however I'm quiet new to Mitsubishis ALVLS-EU Alpha controller software V2.70. What I need...
1,856
