Mitsubishi ethernet A & Q
weekev
May 2002
42
Anyone out there used ethernet as an IO passing network
between a Q series (as the master) and several A series PLCs.
I've read the threads on CC link Mel/10 etc.
On the ethernet subject all info. I've found so far refers
to use as the path for PLC to PC , SCADA etc.
I want to pass data from PLC to PLC
thanks in advance
weekev
Weekev
I have used Ethernet to pass data between several A Series PLC's where I had no alternative. It does, however, require some fairly heavy code. You need to look up "Fixed Buffer Data Exchange" in the Ethernet card manual. Please note that each connection between two PLC's uses two ports and you only have 8 ports available so these must be opened and closed on the fly. My advice would be to use Melsecnet unless you have absolutely no alternative.
Andybr
weeKev.
Re your PM concerning this post. I cannot comment on MelsecH or CC Link as I do not have any experience with these. Ethernet is nothing at all like Melsecnet/Melsecnet B. You will have to write code to pass data between PLC's. The code is fairly heavy going and you will definitely need the Ethernet module manual. I have attached an example for the most basic communications between two A series PLC's. I hope that this is useful.
Andybr
Hi everybody! I have 2 Mitsubishi Q series PLCs that have built-in IP addresses of 192.168.3.xx and both of them have Ethernet modules...
857
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,813
Hello, I have a mitsubishi A800 drive with A8NEIP_2P that I'm trying to communicate with AB Ethernet/IP Card 1756 ENBT/A. I have everything setup...
1,317
Hi everyone, I'm currently configuring a Q-series PLC (Q10UDEHCPU), using GX Wroks 2, and a Q71E71-100 Ethernet communication module to...
2,239
Good afternoon from Belgium. I am trying to configure some Mitsubishi STL-ETH1 head units, but even if I set the dip switches for the last...
2,356
