mitsubishi FX1n/encoder connection
Bill Wendle
Sep 2004
I'm new to plc applications.
Can I connect an encoder to register position in the plc to output an AC Motor drive for bi-directional operation.
I'd like to have a 3 button input to operate the plc/drive to move to position.
confused.
I didn't use FX in a while but as far as I remember they all have high speed inputs (I think it's the first six of them X0-X5). This is in case you want to use quadrature encoder. If you have absolute encoder with parallel output, you can use any inputs but this will consume one input for every bit of resolution you need (might not be reasonable solution on brick PLCs although FX1N is somewhat expandable I think).
In first case (quadrature encoder) you would have to connect A and B encoder outputs to X0 and X1. If your intend to use maker, connect Z output to X2. Make sure to match voltage and polarity or use interface if they don't match.
Hi guys, Im trying to set the real time clock in my Mitsubishi FX1N, but it shows this error ES: 01800001 I have good communication with...
181
Hello people, i'm new with the mitsubishi FX1n-24MT plc and with the gx developer its very new to me and i want to implement for students a stand...
937
Hi, Does any one know how to communicate MItsubishi FX1N or FX2N with or without 485/422bd with Pro-Face GP2300 HMI?? I tried to summon Hades...
2,264
Hi guys, I've encountered a weird problem backing up my old FX1N-24MR-ES/UL PLCs. Hope I can get some helps here. I'm grateful for all the help...
1,890
Hi, I am working on the project that needs to communicate with FX1N PLC by serial port protocol from PC. I am using USB-SC09-FX cable to connect...
2,751
