Mitsubishi GX works 2
allend222
Jul 2018
murfreesboro
On a GX works 2 program I am currently unable to change to online/write/read. I went to Ladder Edit Mode(Z) under the Edit tab to see if I could change it back to read mode and now both options are unable to be selected. Any ideas?
Being OPs single post I assume he figured it out.
Online editing in gx works 2 can be a bit tricky on what icon to press first and how to exit editing wo having code show up as different online offline.
Currently the only type of online I can go is write while online (online edits) or
write mode. I am not trying to switch the program and I have tried to close it out and open it back up but I still am unable to do anything but those two options. Work got pretty busy yesterday and I was unable to get on and reply.
Is it monitoring you wish? And your code is freshly compiled and downloaded?
Please explain further, maybe what plc, maybe pics, did you develop the code. I’ve used gxw2 quite a lot but it was a year ago now and feel I should be able to help if I know more. It’s a friendly software.
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
116
Hi Folks I have made a function block that has the EN input enabled. (FBD language) In want to run some code at the top of the function block as...
1,740
Hello Friends I am a rookie in mitsubishi. I have many conditions in my program, How can I add several lines to a rung? For example: How can I...
1,523
I am having issues generating a CSV file to reference when I print a report on a project I commissioned last month. I understand the process of...
1,537
New to Mitsubishi. Please help me with the following. What's the easiest way to swap bytes with GX Works2. QCPU03D. Reading data from a load cell...
4,022
