Mitsubishi PLC A1SJCPU-S3
blindfreddy
Oct 2015
Sydney
I have a PLC program from a Mitsubishi PLC A1SJCPU-S3.
I am trying to open the program with GX developer v8.8 but when i try and open it I get the following message
"Failed to read the project file. The project cannot be opened. The following causes are thought. The data in the project file is completely damaged. The data is created by new version more than this S/W."
The program is very old so i do not think it was created in a newer version of GX developer.
Is anybody able to open this program or advise the correct programming software?
Thanks,
The software you have is ok for these files
But, there are files missing.
In the 'resource' folder, there should be a file called param.wpa
and in the 'others' folder you should have a file 'comment.wcd'
I put fake ones in (or at least files from another project) and it opened but complained about not enough memory.
You need another copy of this program or a re-upload
Thanks Ronnie,
After adding the missing files you mentioned i was able to open the program in GX developer. Still could not access the ladder logic (got the same error as you not enough memory).
ended up re-uploading the program.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
128
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
115
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
164
