Mitsubishi PLC FX2N-80-MR Prog-E led on ?.
Hi
There was a terminal called Ss which I taught meant start/stop
Sometimes people would wire this to a switch to change the plc to stop mode.
Not saying this is the problem it worth looking at. The other is has some one changed the switch under the cover from run to program.
Donnchadh
First of all check that nobody has set the run/stop switch (near the prog port to stop.
The problem could be loss of battery backup, faulty extension block or code.
Hi
Donnchadh
The terminal labeled S/s is how you select sink or source inputs.
Dave
If the Prog E LED is on, none of the above suggestions are correct.
There is a program error!
This could be many things and you need to connect to the plc to see the error code.
Dear all, I have a FX2N-20MR chinese semi-clon of a Mitsubishi PLC. It has only a serial DB9 port that cannot be removed or exchanged (which is...
2,080
Hi everyone, I am new here and this is my first post. I've just received my new PLC by post. It is a FX2N-20MT, a chinese clone of a Mitsubishi...
28
18,346
good morning every one I have a problem in Mitsubishi plc fx2n the battery led is on and progE/cpuE led flashing the plc in a machine which runs...
2,035
For some background information, I am in the process of converting a Mitsubishi FX2N to a Siemens S7-1200. I am viewing the Mitsubishi program...
2,825
hello people, im ziyaad from south africa. I need advice please!! i purchased a house that has a the mitsubishi fx2n plc installed. All was...
1,546
