Mitsubishi PLC FX5U MODBUS TCP CLIENT example request
tan_bk
Jun 2014
Hanoi
Hi everyone!
I would like to establish Modbus TCP connection between FX5U cpu and another PLC (other maker). And the FX5U will be the client. I am using GX Works 3 programming tool.
I have read FX5 User's Manual (Ethernet Communication) (section 6 - Predefined Protocol support function) and followed its procedure but still not ok yet :cry::cry:🔨🔨
Please help me, any advice or example project are appreciated 🤞🏻🤞🏻🤞🏻
Manual link: http://dl.mitsubishielectric.com/dl/fa/document/manual/plcf/jy997d56201/jy997d56201c.pdf
Error code: C410: Receive waiting time timeout error
Yes, the problem was solved.
In the "Ethernet port parameters configuration", I have to choose "Active Connection Module" instead of "UDP connection module".
I have Active connection module Predefined protocol PLC port number 1282 Device adres 192.168.0.81 and port number 502 and still cant get communication with device. Ethernet diagnosis says TCP status disconnected. When Iam trying to opne connecton i get error
2822HDevice that cannot be specified is specified.
For all who want to do the same.
I have Projectfile for FX5U / GX Works 3 for Modbus-TCP Client (Master) function. Also the file for predefined protocol.
The project is made for communication with external I/O from Crevis. But it's easy to customize.
Unfortunately, I can not upload the file because of the size limit of 375kb! (I feel back in the time of the floppy disk):(. If the project is needed, send a request here.
Thank you Mr. Dave W.!
Could you pls upload your files to other server (EX: mediafire) and post your link here?
Thank you!
Tan
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
172
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,281
Hello, I would like to establish Modbus TCP connection between FX5U and PC computer. Mitsubishi FX5U will be Slave, PC computer will be the...
8,576
64
154
