Mitsubishi PLC
[ENC0 F0 D12345 ...] this is only part of the function should be [ENCO M10 D8 K3] this decodes the 8 bits from M10 (to M17) & gives a decimal value in D8
i.e. if M13 is on then this being bit 3 (M10 being bit 0) then D8 will have a value of 3 M18 will give a result of 4 etc.
the manual is here:
http://www.mitsubishi-automation.co.uk/
This function basically checks a bit on in a range
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
130
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
115
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
164
