Mitsubishi problem
cmulder
Nov 2002
I am using a Mitsubishi A2AS-S1 CPU. I want to set some markers in the internal buffer memory of an ethernet module. To do so I am using the TOP_M function. I use the following variables:
s = ConnectionNo (Type: WORD, value: 16#8003)
n1 = HeadAddress (Type: WORD, value: 8)
n2 = 33
n3 = 1
When I compile my project I get an error saying: "Illegal device used or symbol not valid : TOP W235 H21 W237 H1"
However, when I change input n1 of the TOP_M function from "HeadAddress" to "8" it compiles without a problem.
Can anybody tell me the cause of this strange error, and if so, what can I do to overcome it.
Thanks in advance
Caspar
cmulder,
n1 n2 (S) n3
----[TOP W235 H21 W237 H1]----
The n1 is where your ethernet module is located or what slot on the rack is it plugged into. This has to be represented as a numerical value like H8 or K8. If your ethernet module is plugged into I/O slot 2 the n1 on your buffer memory write function would be H2 or K2 not a link register as you have it. Your (S) is where the data is located thats going to be written. The buffer memory itself is nothing more then a place for other I/O units or other modules to get together to exchange data.
Tim
Second try,.....
cmulder,
n1 n2 (S) n3
Tim
Tim,
Thanks for your reply. I think you are right. I have to use a value like K8. Using a variable just doesn't work. I have noticed that with a QnA-series however it does work.
I'm a bit disappointed now because I wanted to write a library function for Ethernet-communication. However for this I would have needed to enter the headaddress for writing to the buffermemory. I guess I have to think of another way...
Caspar
You should create a function block with input parameter Address as integer. Inside the function block you can use TO instruction with n1 parameterised as Address. It will work. But in a program it does not work because the CPU does not allow a variable as the first parameter for the TO instruction. In a function block it is different.
Hello I am writing to request assistance with obtaining a specific GSD file for our Mitsubishi inverter type A800-E, which is connected to our...
432
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,235
Some time ago, I looked at a form of indirect addressing on Q series PLC's, the normal way is to use the "Z" registers as an indirect pointer, so...
2,004
I have gotten help with some issues in the past on this forum, and I'm hoping someone can help me again. My company is an OEM that used the...
961
Dear All, currently i have a problems with my mitsubishi PLC. i'm using A0J2 (old PLC). when the input is triggered, the output remain same...
1,918
