Mitsubishi Profibus Question
Neuadan
Aug 2011
Auburn Hills Michigan
Hi
I have a Mitsubishi Q12H cpu with a QJ71PB92V profibus master and a Robot controller I/O. I am using gx developer v8.0 and dp configurator 7.0.
I downloaded the setup using the dp configurator and have a solid green Run light, Flashing SD/RD light, Solid Ready light, and a Solid Token light.
I know I to use a move function or TOP function to get the data too and from the PLC but I am not seeing change of states to the D1000 area that is listed in the DP configurator I/O setup.🔨
Someone earlier had a simalar issue and there was a easy profibus setup guide that got sent to him in a link but that as long since ceased to be a valid link.
Hi all, i'm newbie in Mitsubishi PLC. Now i have a Q61P PLC with QJ71PB92V PROFIBUS-DP Master Module. This profibus module to read the data...
2,550
Hi all. Long time reader, first time poster. I am tasked to make a couple of module specific function blocks for communication between our...
2,259
Hello Has anyone used the Mitsubishi Profibus Slave FX3u-32DP Module with GX Works2 The Mitsubishi example code given in the manual is for GX...
2,220
Hi all. I have an older plant with a Mitsubishi PLC that we need to convert to Siemens S7. In the old plant there is used a Sartorius weigh...
5,715
Hello All, Does anyone here have any experience with a Mitsubishi Q series and Siemens 318-2 profibus DP link? I have the Siemens setup as master...
2,769
