Mitsubishi Profibus Slave F3u-32DP Module
gmcgivern
Nov 2012
Newry
Hello
Has anyone used the Mitsubishi Profibus Slave FX3u-32DP Module with GX Works2
The Mitsubishi example code given in the manual is for GX IEC Developer and doesn't compile in GX Works2
I've tried to use the TO/FROM statements but drawn a blank with these also
Red DIA Led keeps flashing
Ok, I now have communications with a Profibus master (not Siemens yet) and can transfer data but the Red DIA Led keeps flashing, any ideas ?
Profibus DIA Led
According to the manual the flashing DIA Led means: -
"user diagnostic message or a DP-V! Alarm/Status message is left unread"
has anyone experience of this on any other Profibus slave modules ?
Hi all, i'm newbie in Mitsubishi PLC. Now i have a Q61P PLC with QJ71PB92V PROFIBUS-DP Master Module. This profibus module to read the data...
2,550
Hi all. Long time reader, first time poster. I am tasked to make a couple of module specific function blocks for communication between our...
2,259
Hi all. I have an older plant with a Mitsubishi PLC that we need to convert to Siemens S7. In the old plant there is used a Sartorius weigh...
5,715
Hi I have a Mitsubishi Q12H cpu with a QJ71PB92V profibus master and a Robot controller I/O. I am using gx developer v8.0 and dp configurator...
2,613
Hello All, Does anyone here have any experience with a Mitsubishi Q series and Siemens 318-2 profibus DP link? I have the Siemens setup as master...
2,769
