Mitsubishi programming cables
amberman
Jun 2014
Brighton
104
I'm shortly off into the relative unknown to commission a machine of ours with a Mitsubishi Q series PLC. I joined the company after it was shipped and no one here knows much about it. I've had a good dig around the software so my only real fear is arriving on site with no means to communicate with the PLC/HMI. UK Mitsi support have told me all I'll need is a USB cable with a square printer style connector but I thought I'd get a second opinion.
The kit installed is:
E1101 HMI
Q03UDCPU CPU
We also have QJ1E71-100 Ethernet module and QJ71MT91 Modbus module - hopefully these only need standard ethernet cables??
Any help appreciated.
amberman
USB is OK, but make sure you have the USB driver installed.
Ethernet will work as well if you know the addresses and a TCP port is available.
E1101 HMI
Q03UDCPU CPU
I know you can use a regular USB to mini USB standard cable and there will be a port for it on the front of the Q03UD. Also the Ethernet modules do use standard Ethernet cables.
Hope this helps,
Dave
OK thanks gents I'll take another USB cable then. Seems hard to find the manual for this CPU on the Mitsubishi website.
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
333
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
290
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
1,968
Hi, My next project is an entirely different platform, its Mitsubishi. I'm using FX Series PLC With 40 Di & 40 DO FX5 80MT and 7" Touch Screen...
3,814
Hello. I first off I wanna say that I am completely new to PLCs and am trying to help fix my Uncles hydraulic press machine that uses a Mitsubishi...
2,796
