Mitsubishi Q series: Adding new modules
intelligent modules must ALWAYS be defined before they are fitted to the backplane, otherwise the CPU will drop into ERR (as you previously seen) with a "PAR ERROR".
Modify the parameter file to reflect the new IO setup, then add the card.
Obviously be aware that the CPU will need to stop, so ensure the plant is safe to turn off for a little while.
Once downloaded the errors should clear with a reset and you should get the RUN light back on.
Normally each slot has 16 bits reserved by default, so in your case this is fine (leave XY assignment as is).
Thanks for your help, appreciate it.
Here's the module I intend to replace, highlighted:
Put the new card in then power back up, you can configure the module afterwards.
If you download the configuration first it may go into stop as it will not detect the card, although once you fit the card it will go back into run.
Is this different to what collinsd70 said? He's suggesting module should be configured first, then inserted.
Maybe both ways are possible.
I need to add a QX10 module to our PLC because we've run out of DI channels. Does this module need to be configured in a similar way to the...
2,219
Hi, I'm planning to install a new Analogue Input module Q68AD-G. It will inserted on Rack 0 Slot 4. When it's installed, will the code recognise...
2,434
I want to add a new ANALOGUE INPUT module into our PLC (Q68AD-G), but I'm a bit confused about something. I would've thought that the IO...
30
18,548
Hi, I've run out of analogue input channels on my Q68AD-G module. If I add a new Q68AD-G module and install it into a spare (blanked-off) slot, it...
1,338
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
39
