Mitsubishi Q-Series
sutton
Mar 2003
Singapore
74
hi all,
I had been given a new project where I'll be using PLC - mitsubishi Q series. i used FX series before, so the Q series look odd to me.
Can anyone tell me what is the main different of Q series and A or FX series?
i was given an example PLC program, there are many things that i dont understand as well. would you guys tell me where to get Q series instruction manual?
whats the different of relay L & M?
thank you :)
think of the difference between the FX and Q as the difference between the Control Logix and micrologix plc's
The Q is much more powerful than the FX, faster too.
best thing to do is look at the website www.mitsubishi-automation.com
Although the new FX2n is a very very powerful plc and I believe the FX3 out soon is even better the Q is a much more expandle and powerful unit. its in a different category to the FX range
My favorite new feature about Q-Series is the use of data bits as contacts or coils.
D1025.5
--| |--------------------------------------------------(D1026.8)-----
Tim
Tim said:
My favorite new feature about Q-Series is the use of data bits as contacts or coils. Tim
That one got my vote also!
Q, Fx, A, they are all the same. If you really see a lot of difference then you should look for another career.
Seriously, this is no way near the difference between CL and ML.
The Q has more functions. It can be programmed in the same way but with more stuff.
Take it easy. Write your program the same way you would with an Fx and when the software doesn't recognise what you do them look for the instruction in the book.
Serial COM module looks like it was developed by AB. It can do everything, page, send Fax, configure a modem (yes, the module configures the modem), dialup, network, and more. So if you only want to remote monitor you'll have a ball trying to configure it.
Beside estetic in program function, its THE SAME.
Also when you configure the CPU you can select for it to be an A serie. It will never see the difference.
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
76
87
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
299
Hi, I have a project with a R04CPU, RD77GF16 and a RJ71PN92 modules. The cell is given to me to change the program since the previous integrator...
314
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,200
