Mitsubishi q02H cpu communication problem
I had similar problems and it is a GX developer bug. Go to Options and uncheck do not write to PLC. Then try again.
Last time the problem already fix by doing this step :
1. Uninstall the Driver from Device Manager about Mitsubishi USB Driver with check condition delete the driver.
2. Install the driver by using Driver from program, in my case the driver located in GX Developer program it's self and it's located in c:/Program files/MELSOFT.
in the forum explain that the driver located in c:/MELSEC, but in my case it located in c:/Program Files/MELSOFT.
when i search for MELSEC folder, i didn't found and download from the forums, and that error occurred. when i install the driver from c:/Program Files/MELSOFT, it's work without error.
in my opinion this problem occurred because the driver that i downloaded from internet not support with my GX Developer.
Thank you
Hello All, Merry Christmas to those of you who celebrate it. I have a Mitsubishi Q02H that I have some set data bits that are lifetime counters...
1,545
Hi All! New guy here, found this place while using Google to research my problem, figured asking the experts has to be easier than banging my...
8,398
OPen to all, Pl help me out to configure the Q series PLC Q02H and E100 digital display unit, so that they both communicate with each other. I am...
3,802
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
39
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
