Mitsubishi Q02H Data Bits
crev64
Sep 2013
Kentucky
Hello All,
Merry Christmas to those of you who celebrate it. I have a Mitsubishi Q02H that I have some set data bits that are lifetime counters and some inputs from a HMI. Everytime I turn the power off, these bits reset. They are all D##'s. Is there some range of D##'s that do not reset when the power is off? I was in D100's and went all the way to D400's. The PLC still remembers the program when I power back on, so it can't be a battery issue.
Thanks,
Crev64
Hello All,
Thanks,
Crev64
You set which registers you want to be latching, (battery backed) in the PLC parameters. Go to PLC parameters under the device tab you can define a range of latching data regs there.
Dave
Hello all.... i have a q02h cpu by melsec iam trying to communicate with usb port but am not able to ......when i go with read from plc and click...
7,077
Hi All! New guy here, found this place while using Google to research my problem, figured asking the experts has to be easier than banging my...
8,398
OPen to all, Pl help me out to configure the Q series PLC Q02H and E100 digital display unit, so that they both communicate with each other. I am...
3,802
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
39
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
