Mitsubishi Q2AS(H) CPU program upload problem
prateek1190
May 2012
Nasik
Hi guys,
I'm trying to read the program from Mitsubishi Q2AS(H) PLC. The communication is fine. But while uploading program, selection for Parameter and Program is not appearing. Only option of device memory is there. So I'm unable to read program.
So what can I do so that I can read the program+ parameter from the PLC.
Regards,
Prateek
make sure the PLC does not use a memory or CF card for program storage
Are you using the old DOS software or the windows version.
Windows version has checkboxes to click to upload certain program areas. I need to job my brain on the DOS software if you are using that.
Hello, comrades. there is an old mitsubishi Q2AS cpu, i want to take data from it to the mx ops server. Can I connect via rs422 directly to the...
1,128
Hi all, I use a Q2AS-S1 CPU, with a Q1MEM-512SE SRAM+EEPROM memory module. I want to save some file registers on the EEPROM. To do so I use the...
2,414
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
64
