Mitsubishi Software
Rheinhardt
Oct 2003
Pretoria
39
GDay Gents,
I have another challenge, i have been given the task of doing changes to a PLC, the SI company does not exist but they managed to give me software copies.
I have GX-Developer Version 8.3 and it is a FX2n-M48R CPU.
The problem is the program is not recognized in GX-Developer is was wondering if this PLC might have been programmed in another Software package.
The files are
custom.sys okb
edm.edm 2kb
lryboxes.sys 1kb
softctrl.pro 3,360kb
My assumption would be that .PRO is the project file. Does anyone know what Package this file extension belongs to?
Many Thanks
Good Morning
Try opening gx developer without opening a PLC file.
Then click "file" and you will see some import options.
Try to import the files, you may have to try a couple of different types, not sure which version of software those file extensions apply to.
Good luck,
Marc
I think the program was probably written using GX IEC Developer. GX IEC Developer is very different from GX Developer and the files are not compatible. It looks like you need to purchase GX IEC Developer to be able to be able to make program changes. Even if you upload from the PLC into GX Developer (which you can do) the resulting program won't be commented and will require a lot of time to reverse-engineer.
I wish you luck.
(Edit: Sorry Mr Badger you got your reply in before me. No offence intended.)
The problem with GX IEC is it uses high order bits (m & D) as temps, these are used over & over again there will be loads of jumps to functions also some logic will not convert to ladder in GX Developer, foe some reason the code is incorrect i.e. open rungs although the logic does run just cannot be interpeted correctly in ladder in GX.
Another problem is that any changes in the plc with GX Developer will not upload to GX IEC even if you have the original source code.
You must keep the project in GX IEC as it cannot be updated from the plc.
There is a possibillity that dependant on the processor that the project has been compacted & downloaded to the plc, however if the project is large & the plc memory small then this is not possible.
This will not work on FX only A & Q series even a moderate program on an A1S meant that there was only enough memory to download the plc program & the compressed source file
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
168
Hi everyone, I'm working on a Mitsubishi Q series PLC whose code was developed in Mistubishi's GX IEC Developer v7.04. I looked online for GX IEC...
1,492
502
I'm looking to purchase either GX works2 or works3 for a Q series rack I purchased off of ebay. Now the confusion comes from either purchasing...
1,375
Does anyone here have suggestions of open source SCADA software that can be used for Mitsubishi PLC FX3U Series. I want to monitor its data...
2,828
