Mixed inputs on 1756-IF16?
markhommer
Jan 2006
Wichita,KS
I am using a 1756-IF16 Analog Input card with single-ended wiring and we require some of our inputs to be 4-20ma and some will be 0-10vdc on the same card. My question is, can we wire this mix of analog inputs on the same 1756-IF16 card? The wiring examples that I have found are for either current or voltage and a mix of both of these are not shown. I know that for current inputs, the iRTN terminals are tied to the RTN and for voltage inputs, the iRTN's are not used, only the RTN terminals.
Any advice is appreciated.
Thanks,
Mark.
Yes, you can. That works fine.
Only thing you can't do, is have some inputs differential, and others single ended.
So all your 4-20mA signals need to be referenced to the common analog signal ground.
rdrast, thanks for the quick reply.
You are correct. I just simulated the mixed signals on our in-house 1756-IF16 card and it does work.
Thanks,
Mark.
I have a system that is all currently 110 AC. It uses a 1769-L30ER with a 1769-PA2, and a 1769-OA8. I need to add 4 2-wire pressure transducers...
1,567
Hello all, I am now working in a Automotive weld shop and am interested in integrating some IAR. I would like to show sensor status and be able...
3,682
Hi guys. I have a data type named P75x_IN. It is defined as User data type and it's members are (in this order): IN_BOOL: BOOL IN_DINT1: DINT...
1,887
Hi, all. I seemed to have hit a wall on my decimal to fraction forum. Therefore, anyone know how to separate a number like 17.33333 into 17 and...
4,067
In the process of moving into a new windows7 desktop PC, I rehosted three licenses from my old machine using the existing version of FactoryTalk...
2,920
