ML1100 RS232 port type and Bootp
Yes, the MicroLogix 1100 supports BOOTP and DHCP for configuration of the EtherNet/IP port. BOOTP is enabled by default.
The serial port is physically very similar to the serial ports on MicroLogix 1000, 1200, and 1500 controllers. It's the same 8-pin Mini-DIN round port, and the same programming cables can be used.
One important difference is that an isolated RS485 port is included, which uses the pins (1 and 8) that are 24VDC power on other controllers. The MicroLogix 1100 has only RTS/CTS handshaking and does not have DCD/DSR/DTR pins.
An easy way to connect the ML1100 to a RS485 network (DF1 half duplex, Modbus, or DH485) is to use the 1763-NC01 "breakout" cable that terminates in screw terminals.
RA Knowbase Answer ID # 38808 has the pinout for the ML1100 serial port.
Hi There, Can anyone help me with the code to do this. I am currently using an AWA instruction and sending the modem string for the message...
3,818
PLC 1763-L16AWA Micrologix 1100 with PVC 2711C-T6C. Replacing the HMI with the PV800 2711R-T7T. I have taken a PV Component program and...
1,985
I do not have any trouble communicating with an LED message sign with my ML1100 when using an rs232 connection. I use a 1761-PM02 cable with one...
5,989
I'm looking to implement a low-cost, efficient method of communicating some integer values to an R30iB robot from a Rockwell 1100 PLC. I am not...
1,733
Hello all, I am trying to setup my MicroLogix 1100 as a modbus RTU master for a modbus network containing multiple modbus RTU slaves. I currently...
3,946
