ML1210 to IDEC HMI (HG1X) comm. problem
vdubguy
Oct 2004
Phoenix, AZ
I am trying to get a 2 port micrologix 1200 to communicate with an IDEC HMI (HG1X) with a pc connected to each. I don't get any comm. between the plc and hmi. (all exclamations) when set to DF1. Out of desparation, (after calling AB and IDEC), I set the pc connected to the 1200 to DH485. Now it is communicating, but it is invalid data. Any suggestions would be greatly appreciated. Thank you.
Did you set everything to match, by defaut the ML1200 uses DF1 at 19200K baud, parity none, 1 stop bit, no handshaking and ID address 1. Verify the PC(s), plc, hmi all have a unique address.
Some ML1200 have a toggle switch under the door that will allow you to switch between default and user configured if it has been configured. This info is in Chapter 4 of the manual.
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
89
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
575
Has anyone interfaced a PLC with a Control Techniques drive Nidec 750 using Modbus TCP? I am attempting to do so using an Automation Direct...
902
I'm involved in upgrading an IDEC FC5A-D12S1E PLC to a FC6A-D32P3CEE. I've attached the original layout of the system. Since then, another HG3G...
444
Hallo all, We are servicing machine automation using PLC Idec FA 2J. I'm trying looking for the PLC user manual, but till now didn't get at all...
791
