[email protected]
I am trying to communicate from a ML1400 to a Yaskawa Servo having an indexer control module using channel 2 and an isolated RS232 to RS 485 Full Duplex converter. The converter is the FA-ISOCON from Facts Engineering (AutomationDirect)which is set up 9600 baud which everything else is also. The sending of commands to the servo works everytime but the response is not seen.I have tried putting first a 10 and then 20 msec delay between the AWA and the ARL though I am now guessing that from Ken Roach's barcode reader example I don't need the delay. I would think that the response would be in the buffer until it is read anyway though. How do the buffers work. I have been using the DN bit of the AWA to trigger the delay which then triggers the ARL. The ARL locks up with EN setand EU but not RN. On the converter I see first the transmit and then rec leds flash and the servo comms monitor shows the receipt of the command and the sending of the response, so?????
Thanks for being here.
Mark
Mark
