MM420 communication question
Farid
Jul 2004
UAE
79
hi everybody,
I am familiar with s7 200 PLCs snd i was wondering how can I write to PZD area or any other area ?? I mean I will use MOVE instruction to move my a value that will mean a certain function to the drive, but how Can I do that? how I will tell the plc to transmit data to that particular area(pzd)??
plz a code/ example would be great,
cause I red all the posts conerning MM420, and I still dont really understand how to do it.
ps: I have MM420 inverter and it does not has profibus port or any thing, it just has P+ and N-.
thanx for any help.🍺
Farid.
Hello Farid;
I will end 3 replies, each with an attached picture.
The first one will show you the Micro/Win add-on you will need to use the USS protocol for communication and control of an MM4 drive with a S7-200. The next 2 are from a pdf document called "USS S7-200" that is available on Siemens' website. You do not need to add a Profibus module to the MM4 drive: connectors P+ and N- are all you nee; of course, profibus cable and a connector on the S7-200 side will be required.
Hope this helps,
Daniel Chartier
now thats what I call help
thanx Daniel ...I really appreciate your help, thats what I was exactly looking for,
best regards:beer:
Hi Peepz, I would like to configure the drive as to control the speed via var resistor? AND another to run at two fix speeds, adjustable via a...
1,454
Hello, I am haveing problems getting a connection between my PC and a MM420 via profi adaptor. Never had these issues until may computer had to be...
2,221
I am new to the whole siemens programming. I have a s7-300 series PLC. ET-200S. I am typically installing GE PLC's. I finally figured out HW...
1,993
Hi everyone! I got a problem :bawling: when I do project on MM420 and CPU 313C-2DP. I read "MM4_Profibus Eng_lit8.pdf" and configured as the same...
1,639
Hi , Is there a Jumper on the MM420 drive to change the Analog input from 0-10V to 4 - 20ma.?
2,055
