Mmc
osamamalhy
Jan 2006
alex
89
Good day
i had Siemens S7 300 PLC
i need to install new MMC on it
did the old one will keep having the existing apllication program on it
did the new one will upload the existing apllication program
Kindly advice
As far as I understand, you are going to replace an old MMC with a new one.
The old MMC will still have the application code on it.
It won't be erased until you erase it.
When you plug your new MMC, your CPU will load the new user program from the MMC.
The application program is always loaded from MMC.
So, whenever you unplug MMC, your CPU will stop because it doesn't have a program.
What are you trying to do?
i am trying to to mdification in the exiting program but with keeping the orginal as it is
also as i know that the PLC only uploading the program from the MMC just in case of total reset is that Correct?
kindly advice
Osama,
From what I understand, You need not have a new MMC to modify the program.
What I do is Upload the existing program in a new project and name it say, "Proj1Upload081117".
Then modify it as required, save it as "Proj2081117" and then download it.
I hope this helps.
Regards,
ali.
Hi Does Siemens supply images for mmc's that have been accidently corrupted or formated?
88
my memory card has been formatted, I'm looking for the image file to use it. Thank you very much 6ES7953-8LF20-0AA0
630
Is there a way in the S7-1500 to read the contents of a directory on the Memory Card? I'm using the web browser to 'upload' .csv files to the...
1,550
we are still running quantum plcs and proworx but because it wont run on any new computers we are starting to upgrade our systems to unity. the...
772
Hi, All I have been tasked with uploading configs from two running Siemens PLCs. One from an ET200 and one from a S7-300. I have no real previous...
1,396
