Modbus configuration
pa_1784
Apr 2007
PUNE
17
Hi All ,
I am using S7 -200 (226 XM ) PLC. I want to connect modbus to it. But i don't know about modbus. To connect modbus what is configuration that should be done in 226 PLC . ( PORT 0 ).
Please send me the answer if any body knows.
Also i want to know where can i get the data regarding modbus basics.
regards,
pa_1784
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
182
Imagine if you were going to request how to configure Modbus/TCP clients and servers in a PLC development software package. What would you want...
804
Hey everyone, I am upgrading Modbus from MVI-56MCM to MVI56E-MCMR? Do I need to change in IO Configuration? I don't know if it is Master or...
1,395
Hello, I am using the Micro830 (2080-LC30-24QWB) with the 2080-SERIALISOL in slot 1. I am having an issue setting up the Micro830 to communicate...
3,225
Hi, I got two questios: There are two slave devices(SEL-787) from which I should read data via MODBUS RTU. I checked SEL-787 manual and it says...
5,576
